We live in a world where data is proliferating, and the traditional methods of storing and displaying data may lead you astray. Fortunately, with the advancements in information technology and the advent of the browser/server model, web reporting emerges with unprecedented advantages. This article will guide you through the definition and significance of web reports, offering practical solutions using web reporting software.
The importance and definition of Web reports
Main Features of Web-based Report
1. What is Web Report?
A web report, or web-based report, is a kind of interactive record presented through the Web, say, using websites as new data transmission platforms. Additionally, it is often used as a part of embedded reporting analytics that is integrated with other software applications to approach more flexible deployment.
The primary objective is to present information understandably and conveniently, eliminating geographical limitations through web reporting online. Therefore, web reports need to be compatible with most mainstream browsers, making them more practical in actual use. Utilizing specialized web reporting software can enhance this compatibility and overall performance.
Report Display through browsers (by FineReport)
2. The Advantages of Web Report
Compared with regular reports, web reports are advanced in:
one example for web dashboard
Web Dashboard (by FineReport)
2.1 Empowering End Users: Remove Limitations with Web Report
The HTML report display ensures the presentation of tables and charts on the browsers. Also, it is worth noting that the browser here is not limited to the PC side.
What does it mean? For example, once you create a report or dashboard with the FineReport designer, you can achieve an adaptive display supporting multiple terminals such as PCs, tablets, mobile reports, and large screens.
Because FineReport is compatible and adaptable to multiple devices, users can access data without being restricted by time, location, and equipment.
Adaptive layout
Adaptive Layout for PCs, mobile, Tablets
2.2 Empowering Insight: Create Interactive Queries with Web Report
The display of web reports makes online queries for users incredibly convenient. As illustrated in the figure below, the parameter pane, supported by web reporting software, enables report developers to freely set filtering and query rules during the presentation.
Through self-service queries on the web, users can engage in various actions, including chart analysis, retrospective analysis, multi-dimensional analysis, etc., enhancing the overall interactive experience.
Add parameters to be more interactive
Parameter Panel for Query (by FineReport)
2.3 Data Security: Fortify Authorization with Web Report
Furthermore, the web portal provides a safeguard for data management, access control, and automatic reporting in the enterprise.
As an example of a Decision-making Platform, with this report management system of FineReport, the administrators can perform authority assignments, security settings, template management, etc. The advantage of these settings is that some confidential documents are exclusive to authorized users, and ordinary users can only view specific reports after being granted access rights.
Web portal for report management
Decision-Making Platform (by FineReport)
2.4 Software for Better Web Report
FineReport is a web reporting tool developed by Java. It provides robust solutions for data integration, data visualization, analysis, data entry & query, and data management across the organization.
What’s more, FineReport embraces a so-called low-coding concept that allows users to quickly design and implement reports and dashboards through an Excel-like design interface and a drag-and-drop mode.
Excel-like interface
Excel-like Interface
3. A Conclusion of Web Report
Web reports are arguably the next generation of innovative tools, offering end-users extensive features without leaving the web application. This approach also opens a window for end-users to view the data saved in a specific software application.
FineReport, equipped with various competitive edges in web reporting software, stands out as the top choice to convey your insights from data. Curious about these stunning visual effects? Explore FineReport to embark on your exciting data adventure, and the personal version is free!
For enterprise users, reach out to us for an exclusive quote on our premium enterprise edition software! Elevate your business with cutting-edge solutions tailored just for you.
Feel free to make an appointment for a live demo with our product experts. We will be more clear about your needs and see how FineReport can help you and your organization transform data into value.
Reporting Tools | 8 min read
Do you know the differences between reporting and analytics? This article illuminates in terms of definition, purposes, methods, and output examples.
03-03-2021
Reporting Tools | 10 min read
This article will tell you what is mobile reporting, how to design mobile reports efficiently and recommend mobile reporting tools to simplify your work.
08-24-2020
Data Visualization | 8 min read
For data analysts, visualization is always a timeless study because it reveals to us the laws behind the data. This article is a guide to…
05-31-2019
