Employee attendance has always been a hot topic that business owners may care about. Through attendance data, you can get a general understanding of the basic performance of employees. At the same time, attendance is also an important standard for salary base. For some companies, matters such as production and customer support require timely employee attendance. Low attendance rate is closely related to low employee success rate. The attendance dashboard & reporting system can strongly help you.
Your Company may not Need a Time and Attendance Machine Anymore!
The times are developing rapidly, and many enterprises still use punch-card machines to solve attendance problems. They think they can solve enterprise attendance problems by attendance machines, and there is no need to spend money to buy attendance management software.
Obviously, they don’t understand the huge burden reduction effect of the automatic attendance reporting system on the enterprise, or their enterprise scale is too small and can be easily managed only by manual attendance, so it is not time to rely on high technology.
However, how does the attendance report and dashboard improve the efficiency of the enterprise’s attendance management? You will find the answer in this article.
The traditional attendance method is to use the attendance machine for attendance, including IC cards, fingerprints, etc. However, the attendance method is relatively simple, especially for field staff (those who often work outside office). Field staff does not have a fixed workplace, even their working hours are not fixed. As a result, companies cannot track the whereabouts of field employees. To fix these problems, the attendance management system can not only provide a variety of attendance methods, but also support GPS positioning for field staff, and the field staff can complete the punch card through the mobile phone. With attendance dashboards, companies can display the overall attendance over the company and diagnose the problems, which greatly improves the efficiency of attendance.
So how to build a complete intelligent time and attendance reporting system? Here we use FineReport as an example.
You can also see the video tutorial here.
Intelligent Analysis of Attendance Dashboard
The enterprise human resources department can customize and set the attendance time and attendance area in advance on the attendance report and dashboard making.
First, you can check the working day from the calendar, it supports customization.
embed a attendance calender
Download Template
When you set the working day and rest day in the calendar, you can set the attendance time directly in the table below. The two tables will automatically match to help you complete the setting of the attendance time for working day and rest day, greatly improving efficiency.
attendance report
Download Template
The attendance reporting system can synchronize the attendance data of each terminal of the attendance machine and mobile phone. The system will intelligently determine whether the employee’s punch time is normal or late, leaving early or leaving the office through the set time.
automate the attendance reporting
Download Template
Based on these data, the system can automatically calculate the employee’s leave and normal working hours. If there is no automatic attendance reporting, then the human resources department will waste a lot of manpower and time to make statistics and calculations, resulting in many mistakes.
In addition, if the employee has abnormal attendance, the employee can also initiate an appeal in the attendance system, and the relevant personnel of the human resources department can also handle the appeal on the system, which is very convenient.
Attendance Dashboard and Salary Calculation Automation
When there is no attendance reporting system, the attendance data needs to be manually counted, and the personnel needs to export the data of each attendance machine and then calculate them together. The time and attendance system built by FineReport can get through all the data of the time and attendance machine, and at the same time automatically generate the time and attendance report without manual statistics, which greatly improves the efficiency of personnel.
attendance report
Download Template
At the same time, the attendance data can be automatically matched with the set attendance time, and the monthly salary can also be calculated automatically, which saves a lot of accounting time for financial personnel, and almost no mistakes.
Attendance Dashboard to Keep Abreast of Employee Attendance
Attendance dashboard
Attendance dashboard -from FineReport
With the attendance dashboard, the display of attendance information is only a matter of seconds. Therefore, the attendance data does not need to wait for a month before being exported for processing. It can be exported every day in a real-time manner. And now the department manager can clearly understand the attendance situation of each employee in a timely manner. With more data support, HR managers can make more scientific decision on enhancing the staff’s attendance awareness and improving attendance management efficiency
We can also make a large screen of attendance data through the excellent visualization function of FineReport. The key data is clear at a glance, and we no longer need to find data from dozens of reports. Excellent interactive functions can help to further understand the details of the data, and also support drill down to query and formulate data.
What’s more, the FineReport have various templates for HR reporting. Welcome to take advantage of them.
Download Template
Conclusion of Attendance Dashboard
In general, using the time and attendance system can not only improve the efficiency of HR but also adjust the relationship between employees and the company. Employees no longer need to queue up and punch cards to affect the mood of the day. At the same time, when employees go out to visit customers or on business trips, they can use mobile punching cards to let the leaders understand the employees’ work conditions. They can also appeal to superior leaders when they encounter abnormal attendance.
Product Functions | 6 min read
Using parameter query and data entry to make your report automatic and in process.
04-24-2020
Dashboard Tools | 4 min read
It wastes your time to analyze and interpret huge amounts of data manually. Dashboard tools could handle your business well. Click here to explore more…
11-10-2021
Dashboard Tools | 7 min read
This post will cover the definition, importance, and designing guide on strategic dashboards. Click to get the 8 tips for building strategic dashboards.
10-09-2021
