Data Visualization Using FineReport FineReport | BI Reporting and Dashboard Software
In the second half of last year, FanRuan held a four-month plug-in development contest with a total prize pool of 300,000. It attracted more than 2,000 participants from all over the country to sign up, and a large number of very beautiful plug-ins emerged.After testing, it will also be launched on the FanRuan market (application center), which can be widely used in the report product FineReport!
Today I will show you some beautiful plugins:
3D Earth: Four-dimensional space-time display and information management, unprecedented visual impact
Author:Qian Hu
Function:Stereo Earth is a very good cross-regional geographic information-based data carrier. Compared to the flat map, the 3D Earth is more vivid and expressive. The 3D Earth plug-in supports point annotation based on quantity and position and flow direction map with two positions and time dimensions. It realizes 3D display and spatial information management in the Web environment, and also publish information, share data and communicate based on the report platform. And based entirely on the B/S mode, it seamlessly interfaces with the decision-making large screen.
Application:Widely used in land resources, cross-border transportation and cross-border trade.
3D panoramic map: Constructing HTC scenes at the metro level
Author:Little_U_U
Function:The 3D panoramic map plugin brings time and space to FanRuan. In terms of time, the plug-in supports the use of date as a dimension, dynamically rendering the trajectory of the point on the map, and supports multiple trajectory classifications;
From a spatial perspective, the plug-in makes the urban building out of the plane ,three-dimensional, and provides the mouse Interaction. Not only that, but the customized plug-in also supports real-time refreshing of data, displaying multiple markers on the map, dragging the map with the left button, and holding the right mouse button to move the view.
Appliction:Government departments, chain companies, LBS providers and other users who are sensitive to real latitude and longitude and display area
Trackmap: Helping companies easily track millions of terminal real-time tracks
Author:Qian Hu
Function:The Trajectory Map plugin supports various configurations of latitude and longitude point data animation, including the speed, color, smearing, order, etc. of the motion trajectory. After the Finereport user configures the track map plug-in, it can simultaneously manage and track the trajectories of tens of millions of terminal devices in the report or large screen.
Application:It is suitable for logistics fleet management, Internet startups to share travel screens, field personnel management report monitoring systems, and healthy Internet of Things using smart wearable devices.
Carousel ring map: donuts with seventy-two variations
Author:Xing Zhou
Function:The ring diagram, the essence of which is the pie chart to hollow out the middle area. The overallity of the pie chart is too strong, and we will focus on comparing the relationship between the individual sectors in the pie chart. But if we put two pie charts together, it is difficult for the pie chart to compare the two images at the same time. When solving the above problems, we have adopted the practice of letting us pay more attention to length rather than area.
This way we can compare different ring diagrams relatively simply. At the same time, the ring map is more efficient than the pie space. For example, we can use its hollow area to display text information, such as the title.
Application:This plug-in adds the functions of the automatic play series required for large screens based on the integration of the domestic well-known open source chart library ring map, and provides a variety of switching animation schemes.
Sankey diagram: a visual analysis tool for data such as energy, material composition, and finance
Function:The  Sankey diagram consists of traffic, nodes, and edges, and is suitable for node datasets (optional) and edge data sets. Data weights are mapped to the width of nodes and edges. Sangiti needs to maintain energy conservation, not creating flow in the middle process, and the lost (loss) flow should flow to the node representing the loss.
Application:It is commonly used for visual analysis of data such as energy, material composition, and finance.
Image carousel: support 3D switching and other special effects
Author:Xing Zhou
Function:The use of images in decision-making reports requires the help of plug-ins. The normal image control designer plug-in can only display a single image, which can not meet the user’s display needs.
Today I brought you an upgraded version of the picture control, the picture carousel control. Similar to the chart rotation, the picture carousel control supports multiple images at the same time, and can configure the playback effect of the display animation.
Application:Suitable for all kinds of scenes that need to be rotated for multiple images.
3D dynamic word cloud: super cool 3D dynamic word cloud, support for click and active play
Author:Duan Jianliang
Function:Creating a beautiful word cloud usually requires a large amount of data and a significant difference in the amount of data before the different fields. The 3D word cloud plug-in supports a deeper word cloud effect through the same configuration as the built-in word cloud. This plugin supports custom chart style configurations, including configuration features such as background color, word cloud color, legend, 3D dynamic rotation direction, and 3D dynamic properties.
Pictogram: Make the data more expressive
Author:Long Yin
Function:In general business reports, the use of column charts is very extensive and is the most common type of chart, but monotonous column charts do not vividly express data in all scenarios. The pictogram column diagram is an extension of the column chart. It can express the data by the length and width of the figure, or the number of the figure, even the color of the figure, the change of the transparency, and the meaning of the data.
In addition, pictograms can also represent values using the same number of graphs, achieving effects similar to those in the figure below. Therefore, the pictogram column can largely satisfy the drawing requirements of the information map.
Application:Suitable for most column charts
Weather control: let the data screen more temperature
Author:Long Yin
Function:Many of the production users of the soft report are database-related operation and maintenance personnel. It is very troublesome to use js to obtain weather information at the front end. So in this visual plug-in contest, developers have also innovatively launched a “weather visualization” plugin.
The weather control supports three built-in styles, which can be contacted with the soft technical support or sales to get more form customization, support the location based on ip, or specify the city that displays the weather. Supports the configuration of double background color and temperature, text styles that describe the typeface, and supports the display of right angles and rounded corners.
Author:Little
Function:Not only the stereoscopic column, but a new dimension, you can put more data in the same space of the same chart, and add a lot of property settings, can display gorgeous display effects, and can automatically rotate Let users intuitively feel the effect of the data.
3D scatter plot: help you find more data in 3D space
Author:9410
Function:The 3D scatter plot, also called the X-Y-Z plot, presents all the data in a three-dimensional coordinate system in the form of points to show the degree of phase interaction between the variables. The position of the points is determined by the value of the variables. By observing the distribution of data points on the scatter plot, we can infer the correlation between the variables.
If there is no correlation between the variables, then the scattered points will appear as discrete points on the scatter plot. If there is some correlation, most of the data points will be relatively dense and present in a certain trend. For those variables that have a close relationship, but these relationships are not as accurately expressed as mathematical and physical formulas, scatter plots are a good graphical tool.
Data collision graph: Have you seen data that will fight?
Author:Onlyxx
Function:Supports the contrast between two values, showing two data in the form of a percentage, and when its specific value changes, it can produce a unique zoom-in and fade-out animation effect, which vividly attracts the user’s attention. The traditional bar chart data display is a static chart.
3D card animation: a dynamic visual feast that can turn around
Author:Qian Hu
Function:In the large-screen display, there is no good solution to the processing of dense images, such as the desire to display multiple product lines or different marketing cases. In the project requirements, I hope to deepen the intensive pictures, stereoscopically present and bring more cool animations or switching effects. The 3D card animation plug-in is a plug-in for the developers who are the closest to the soft native graphics experience. First, its coolness is beyond the limits of the traditional FanRuan  chart.
Since you can customize the path of the image and the location where it is displayed, you can even make a periodic table of elements, which of course can be the logo of the company or the image of an important product.
Bullet map: a bullet map that is more effective than the dashboard
Author:Mei Liangxing
Function:The bullet map looks like a track that is taken out after the bullet is fired, so it is called a bullet map. The bullet map was invented to replace the odometers commonly used on dashboards, and speedometers and the like based on circular information representation.
The unmodified linear expression of the bullet map enables us to express rich data information in a small space. The linear information expression is similar to the text reading we are used to, compared with the circular composition of information expression, there is a greater performance advantage in information transmission.
Flowchart: FineReport also supports drawing flowcharts
Author:Standard citizen
Function:In the daily management process, enterprises will generate a continuous specification of a large number of behavior patterns. This scenario is usually described by a flow chart. Common flowcharts are classified by describing different objects, including: business process diagram, page flow chart, function flow chart, data flow chart, and so on.
The use of flow charts can help business managers sort out product development, personnel and financial processes, and effectively reduce communication costs between team members. It helps to improve and optimize the product demand plan and evaluate the company’s business leads.
Application:It is applicable to the daily management of most enterprises
Dynamic water balloon: make the data wave
Author:Little
Function: The water polo map is a type of chart suitable for presenting a single percentage of data. Through a simple and clear data interface and feature-rich style configuration items, users can quickly generate cool water polo maps instead of traditional dashboards and other graphs showing percentage data. You can also use it to display various levels of progress.
Application: The water polo map can more accurately display the percentage data and the continuous relationship between the percentages.
Scrolling the report graph: scrolling the report graph makes the large screen more cool!
Author:Little
Function:The traditional decision report block is static, the list does not scroll, the data must be displayed at one time, the effect is not cool enough in the large screen, and the latest data cannot be automatically obtained.
This plug-in supports the presentation of reports in the form of graphs. By setting the dataset, it displays a list of similar report blocks, supports user zero code to obtain database information and configures automatic update time, supports configuration of headers by field names, supports custom color configuration, etc. A variety of configuration items to help users make cool decision reports and even large screens.
Mini Figure: Remember the minimap in the Excel cell? FineReport also supports it!
Author:onlyxx
Function:The mini map supports three forms, namely a bar chart (supporting a profit and loss chart with negative numbers), a line chart, and an area chart. And support users to set the axis, uniform color, adjust the background, directly preview the final effect in the panel. So although the user’s report looks just as flat as the traditional report in the main interface of the designer, it becomes very vivid after the preview.
Application:Often used for business data expression, such as stock trends, market conditions, etc.
Combination chart: When the bar chart meets the pie chart, boom!  Awesome!
Author:Matches
Function:Bar charts and pie charts are very common chart types. The former is often used to show the size comparison of data. The latter is good at describing the relationship between parts and the whole. When a bar chart displays multiple series of multi-category data, it tends to be complicated and difficult to understand. The relationship between the bars is not clear, and the pie chart can make up for the disadvantages.
In addition, when making decision reports or  large screens, the use of this plug-in is not only cool, but also supports automatic playback, smooth animation playback, and easy unattended display.
Application:It is often used for quarterly classification, departmental series, and various sales and personnel data charts.
Related Posts
© All Right Reserved
