Except for attributes what we have said, today we will introduce some Other Attributes of FineReport business intelligence tool in this article.
Click menu Cell > Other Attributes or right click to select Other Attributes or select Cell Attribute Table > Other Attributes at the right of report body, a Setting Interface of Other Attributes will be displayed at the right, as shown below:
Autofit
Auto fit row height or column width of the cell in report designer. Select default method and the designer will fit the row height and column width based on the row height and column width plan as stated in the Template > Page Setting >Others
Autofit:No
the current cell will be displayed in the actual size in designer if it is displayed at web side or is printed and exported. The cell contents will be cut out for display.
Autofit: Row height
When the designer size is too small to hold all texts of current cell. When the cell is displayed at web side or is printed and exported, the column width will keep unchanged and the row height will be changed automatically depending on the text to display all contents.
Autofit: Colum width
When the designer size is too small to hold all texts of current cell. When the cell is displayed at web side or is printed and exported, the row height will keep unchanged and the column width will be changed automatically depending on the text to display all contents.
Autofit: Default
Note: Autofit default option in the cell is default autofit.
Preview
Preview the cell content or not, i.e., display the content of cell that is going to be displayed or not.
Print and export
Print or export cell content and background or not.
For details about preview, print and export, refer to Preview, Print and Export Cell
Display content
Set the way to display cell content:
Option Function
Default Display cell content by default
Display content with image Display content with image
Display content with HTML Display HTML fragment
Display binary content with download linkage If the field is binary data, it is available for download.
For details, refer to Cell Display Content
Content prompt
When the mouse is moved to the cell, the cell will display set prompt content, as shown below:
Support formula input. For details, refer to Cell Content Prompt
Page break
Option Function
Page break before row Page break before a row when each page has displayed fixed rows.
Page break before column Page break before a column when each page has displayed fixed columns
Page break after row Page break after a row when each page has displayed fixed rows
Page break after column Page break after a column when each page has displayed fixed columns
Allow break in page break Allow break in page break
Repeat display when allowing separation in page break Repeat display of value in page break break
For details, refer to Page Break in Groupsin
Insert rows
When inserting a new row in the filling report, you may insert a null value, a default value or an original value for specified cell.
For details, refer to Insert and Delete Rows
