Before learning Filling chapter, you need to understand the FineReport reporting software internal Control.Filling control is used for data entry in web side.
1. Description of fill report
Filling control is used for data entry in web side. Only when the cell is bound to the control, can you input and fill data in web side.
2. Add control for fill report
Select cell and right click to select Control Setting. The system will pop up Report Filling Attribute, where you can bind a control to the cell, as shown below:
2.1 Control type selection
Similar to Parameter Control , filling control also has several types. Select one from the Type drop-down box:
Determine the control type to which the cell is bound based on the data attribute to be filled.
2.2 Control attribute setting
Different controls have different attribute settings. Description will be given taking text box as an example, as shown below:
2.3 Data dictionary
Data dictionary is to bind alternative data analysis to control. You can directly select one without manual input, as shown below:
Note: Not all controls have Data Dictionary option.
2.4 Event editing
During control usage, you can add events to realize some other effects. Time types of events are determined based on control trigger time, as shown below:
For detailed introduction about event editing, refer to Control Event.
