How many cell elements in our business intelligence?
Cell elements in report designer include data column, normal text, rich text, formula, chart, picture, slash and sub-report, as shown below:
1.1 Data column
Click menu Insert > Cell Element > Insert Data Column or right click Cell Element > Insert Data Column to insert the data columns in a template data set.
1.2 Normal text
Click menu Insert > Cell Element > Insert Normal Text or right click Cell Element > Insert Normal Text to insert a normal text.
1.3 Rich text
Click menu Insert > Cell Element >Insert Rich Text or right click Cell Element>Insert Rich Text to insert a rich text. For detailed usage and meanings of rich text, refer to Rich Text.
1.4 Formula
Click menu Insert > Cell Element > Insert Formula or right click Cell Element > Insert Formula or click the button in toolbar to pop up Define Formula interface.
Input formula in the Text Edit box:
Click OK to insert a formula
1.5 Chart
Click menu Insert > Cell Element > Insert Chart or right click Cell Element > Insert Chart or click the button in toolbar to pop up Insert Chart interface.
Click Complete to insert a chart.
1.6 Picture
Click menu Insert > Cell Element > Insert Picture or right click Cell Element > Insert Picture or click the button in toolbar to insert a picture.
1.7 Slash
Click menu Insert > Cell Element > Insert Slash or right click Cell Element > Insert Slash or click the button in toolbar to insert a slash. An interface as shown below will pop up:
Input slash text and click OK to finish this operation.
For example, input Product and Year, as shown below:
Effect is as follows:
1.8 Sub-report
Click menu Insert > Cell Element > Insert Sub-report or right click Cell Element > Insert Sub-report or click the button in toolbar to insert a sub-report. An interface as shown below will pop up:
Select sub-report position and click OK to finish this operation.
