What is cell content prompt? And how to operation it in our report designer? We wil introduce it for you.
In business intelligence tool, Cell content prompt is similar to Word note. When the mouse is moved to corresponding cell, a corresponding prompt will pop up.
Sometimes, only partial content will display due to limited cell size. In this case, you need to use corresponding prompt to see all contents. Effect is as follow:
2. Setting method
At the cell to be added with a prompt, Right Click Cell> Other Attributes or directly select the cell and select Cell Attribute Table > Other Attributes in the Cell Attribute Table at right of report, as shown below:
When the mouse is moved to corresponding cell, all contents will be displayed. The effect is as shown below.
Note: Data point prompt supports formula.
