Design for Reporting: Effect Display Techniques
It is a typical cross template, consisting of slash cell, aggregation cell, formula cell and chart cell. It supports grouping horizontally and vertically and parameter query. The following section will introduce the whole process of how this template is made, deployed and displayed, leading you to a new application system developing journey started by FineReport Reporting Tool.
design reports
Design for Reporting: Getting Started with Report Designer
1. Start Designer
After downloading the installation file from FineReport official website, please follow the guide to install FineReport on your computer. You can also refer to Installing FineReport to finish the installation. Then you can can click Start>FineReport_8.0>Designer to start designer.
design reports
2. Activate Report Designer
It is required to input user information to activate the designer at the first time as shown below.
design reports
Click the ‘Click to get activation code‘ button, the dialog box will link to our official webpage. Please leave your e-mail address and the activation code will be automatically sent to your e-mail box within a few minutes. Come back to fill the blank with the code, click Use Designer button, and then the designer will be activated successfully.
3. Connect to Database
After starting designer, click menu Server(s)>Define Data Connection, then a dialog box will pop up as shown below.
design reports
The designer has connected to a database named FRDemo by defaul, click Test Connection and the pop-up dialog box will inform users of the results. There are other connection methods, such as JDBC, for which users can refer to JDBC Connect to Database.
Now we can use data in database to design template since FineReport designer has connected to database.
Design for Reporting: Creating New Workbooks & Datasets
Click design reports from the Quick Toolbar to create a new workbook.
design reports
In the lower-left corner,there is a Template Dataset window listing all the available datasets. Click button to add a dataset.
Create a new dataset ds1 and define the SQL statement as SELECT * FROM sales where region =’${region}’. This is an SQL statement with parameter whose name is “region”.
Click Refresh button in the parameter panel below and users can obtain the parameters of the dataset. Set the default value as “East”, click Preview and the effect is as shown below.
design reports
Create dataset ds2 in the same way and define the the SQL statement as SELECT * FROM salesvalue.
Design for Reporting: Design Style
The effect is as shown below:
design reports
Title: Merge cells A1 to D2 and input Region Sales Situation.
Border: Select area from A3 to D5 and click design reports in the toolbar; open the drop-down menu and select design reports to add frames both inside and outside.
Slope lines: Merge cells A3 to B3, right click the cell and select Cell Element. In the drop-down menu, click Insert Slope Lines. The system will pop up a dialog box to edit the slope line, input information we’d like to add: product |sales| region. Users can also adjust the words through adding spaces. Effect is as shown below.
design reports
Design for Reporting: Bind Data Column
The final effect is as shown below.
design reports
1. Bind Data Column
Drag the data column to the cell and set properties. The setting position and method is as shown below.
design reports
Following the method below and drag other data columns to the corresponding cells and set properties as shown below.
design reports
2. Multi-dataset Linkage
Because the data comes from two different datasets, it is required to use data filter to build connections between them. Select cell D4 and click the Filter button in the upper right corner of the property panel as shown below.
design reports
Open Filter setting panel and add conditions as shown below, make sales of ds2 equal sales of ds1.
design reports
Design for Reporting: Parameter Panel
In most cases, users need to use parameters to display part of the data that meets certain requirements. Here, parameter design is actually a dynamic process of filtering data, helping the user to realize real-time interaction with data. FineReport reporting software has an embedded parameter panel to allow users to adjust the positions of parameters; moreover, users can get different data selection style through widget setting. We will introduce the design process of parameter query on the basis of previous report.
1. Layout of Parameter Panel
Click Parameter Panel and you will enter the editing interface. In New Workbook and Datasetsection, we defined parameter region in dataset ds1. The defined parameters will display in the lower-right corner; click Add All, FineReport will use default layout to generate parameter interface, where users can adjust the panel as they wish.
design reports
2. Style of Parameter Control
Select ComboBox as the control’s type as shown below.
design reports
Select ComBox control and set its dictionary in the upper-right corner. Select Database Form> FRDemo>sales and define Actual Value and Display Value as Region.
design reports
Design for Reporting: Define Charts
Apart from table, FineReport can also use chart to visually display data. We will add chart display on the basis of the previous template to show every product’s sales conditions. We will select the cell data source, which means the data come form cells.
1. Insert Chart
Merge cells from A7 to D18 and click Insert>Cell Element>Insert Chart on menu. The dialog box will pop up as shown below. Here we choose Column Chart and click OK.
design reports
Then select Chart Properties-Data in the upper-right corner. Set Datasource by default.
Input formula: Category=B4
Set Series Name and Series Value separately=C3 and =C4.
The effect is as shown below.
design reports
2. Set Expansion Properties
We only want the chart here to reflect the whole conditions, so the Left and Upper Parent should be set None. Select the chart and Cell Properties-Expansion setting panel is in the lower-right corner as below.
design reports
Preview for Design for Reporting
Input
http://localhost:8075/WebReport/ReportServer?reportlet=GettingStarted.cpt
in browser to view the chart.
design reports
According to the process of creating the frist report, we can summarize the procedure of template making as shown below:
design reports
