The era of data analysis has already arrived. From the state, government, enterprises to individuals, big data and data analysis have become hot words that everyone is familiar with. But you may not have the professional knowledge of data analysis and programming, or you have learned a lot about the theory of data analysis, but you still can’t practice it. Here, I will compare the four tools that are most popular with data analysts, Excel, R, Python, and BI, as the basis for getting started with data analysis.
1. Excel
1.1 Usage Scenarios
  • Data processing work under general office requirements
  • Data management and storage of small and medium-sized companies
  • Simple statistical analysis for students or teachers (such as analysis of variance, regression analysis, etc.)
  • Combine Word and PowerPoint to create data analysis reports
  • Assistant tool of data analysts
  • Production of charts for some business magazines and newspapers (data visualization)
1.2 Advantages
  • It’s easy to get started with Excel.
  • The learning resources are very rich.
  • You can do a lot of things with Excel: modeling, visualization, reports, dynamic charts, etc.
  • It can help you understand the meaning of many operations before further learning other tools (such as Python and R).
1.3 Disadvantages
  • To fully master Excel, you need to learn VBA, so the difficulty is still very high.
  • When the amount of data is large, there will be a situation of stuttering.
  • The Excel data file itself can hold only 1.08 million rows without the aid of other tools, and it’s not suitable for processing large-scale data sets;
  • The built-in statistical analysis is too simple and has little practical value.
  • Unlike Python, R and other open source softwares, there is a charge for the genuine Excel.
2. R
2.1 Usage Scenarios
The functions of R cover almost any area where data is needed. As far as our general data analysis or academic data analysis work is concerned, the things that R can do mainly include the following aspects.
  • Data cleaning and data reduction
  • Web crawlers
  • Data visualization
  • Statistical hypothesis testing (t test, analysis of variance, chi-square test, etc.)
  • Statistical modeling (linear regression, logistic regression, tree model, neural network, etc.)
  • Data analysis report output (R markdown)
2.2 R vs Excel: Is R Easy to Learn?
From my point of view, getting started with R is very simple. 10 days of centralized learning is enough for mastering the basic use, basic data structure, data import and export, and simple data visualization. With these bases, when you encounter actual problems, you can find the R package you need to use. By reading R’s help files and the information on the network, you can solve specific problems relatively quickly.
3. Python
3.1 Usage Scenarios
  • Data crawling
  • Data cleaning
  • Data modeling
  • Construct data analysis algorithms based on the business scenarios and actual problems
  • Advanced fields of data mining and analysis, such as machine learning and text mining
3.2 R vs Python
R and Python are both data analysis tools that need to be programmed. The difference is that R is used exclusively in the field of data analysis, while scientific computing and data analysis are just an application branch of Python. Python can also be used to develop web pages, develop games, develop system backends, and do some operation and maintenance work.
A current trend is that Python is catching up with R in the field of data analysis. In some respects, it has surpassed R, such as machine learning, text mining and other areas of programming. But R still maintains an advantage in the field of statistics. The development of Python in data analysis has modeled some of the features of R in many places. So, if you are still newbie and haven’t started learning yet, I suggest you start with Python.
Both Python and R are easy to learn. But if you learn both at the same time, it will be very confusing because they are very similar in many places. So it is recommended not to learn them meanwhile. Wait until one of them has mastered a certain degree and then start learning another one. Wait until you master one of them, and then start learning another one.
3.3 Choosing R or Python?
If you can only choose one of them to learn because of the limited time, I recommend using Python. But I still recommend that you take a look at both. Maybe you hear in some places that Python is more commonly used at work, but solving problems is the most important. If you can solve problems efficiently with R, then use R. In fact, Python mimics many features of R, such as DataFrame of Pandas. And the visualization package under development, ggplot, mimics the very famous ggplot2 in R.
4. BI
There is a saying in data analysis: the text is not as good as the table, and the table is not as good as the graphic. Data visualization is one of the main directions of data analysis. The charts of Excel can meet basic graphics requirements, but this is only the basis. The advanced visualizations require programming. In addition to learning programming languages such as R and Python, you can also choose BI tools that are simple and easy to use. For an introduction to BI, you can read my other article What Data Analysis Tools Should I Learn to Start a Career as a Data Analyst?.
Business Intelligence was born for data analysis, and it was born with a very high starting point. The goal is to shorten the time from business data to business decisions. It’s about how to use data to influence decisions.
The advantage of BI is that it is better at interactions and reporting. It’s good at interpreting data that has occurred and is happening. It can greatly liberate the work of data analysts, promote the data awareness of the entire company, and improve the efficiency of importing data. There are a lot of BI products on the market. Their principle is to build dashboards, through the linkage and drilling of dimensions, to obtain a visual analysis.
I think everyone is familiar with BI tools like SAP BO, Oracle, Power BI and Tableau. Here I want to tell you a zero-coding tool, FineReport. It is very friendly to beginners in data analysis. With no need for any basis of learning programming languages, you can easily master this software.
FineReport is a professional, simple and flexible enterprise reporting system, architecturally designed based on “no-code development” concept. Traditional open source softwares have limited functionality and cannot meet individual needs. There is no service guarantee. And they have high learning costs and require long-term learning. FineReport provides solutions to tackle all these difficulties.
It has three main functions.
Data integration
FineReport delivers multi-data source correlation, cross-data base and cross-data sheet access and the simple application of multi-business system data. It also integrates related businesses data into one report, enabling more data to be applied in operation analysis and business control.
Data collection and modeling analysis
The report designer allows the user to design the required reports in a flexible and simple way. The reporting portals enable the common access and management of reports and achieve the data analysis and filling of various businesses.
Data display
Data can be accessed via PC or mobile terminals. To improve the reading of report data and the exploration of data value, FineReport offers such functions as the analysis of a wide variety of charts, drill-through analysis, multi-dimensional analysis, custom analysis and real-time analysis.
Real-time dashboard of FineReport
One more thing of R vs Excel
As the speech of Steve Jobs, the surprise egg is placed at the end!
The personal version of FineReport is completely free. You can go to the official website to download and try it.
Follow FineReport Reporting Software on Facebook to know more about data analysis tools!
Dashboard Tools | 11 min read
Monitoring dashboards can help check whether businesses are developing as expected. Click to know monitoring dashboard examples, templates & software.
08-09-2021
BI Tools | 16 min read
Business intelligence system can benefit business analysis and decisopn-making. Click this article to know how BI system works and useful BI system tools.
07-16-2021
Information technology (IT) dashboard tracks KPIs efficiently to aid corporate analysis and decision-making. Click to know more details about IT dashboard.
08-25-2021
