FineReport
Professional knowledge and discussions about reporting tool
Java reporting tool with a fixed number of records FineReport achieve pagination
In pagination preview the report or print the report came out, often require a fixed number of records paging, making it more convenient to browse the report, print it out and more beautiful. Use “condition attribute” FineReport reporting tool functionality can easily achieve this effect.
Here to introduce Web Reporting Tool FineReport achieve a fixed number of records in accordance with the detailed procedure paging.
1.Reports template design
In the following figure in the report, requires each of which has six rows records, and each page has a fixed record last used for sales representatives to sign
Reports template
2.Set the repeat header row
When the web page preview or print a web report page, so that each page has a title line display for easy access. In FineReport Report Designer, right-click the first row, select “Set repeat header row”, the first line will appear (H) of the mark, as in Figure 1.
repeat header
3.To count the number of records
Write the formula = & B2 in cell A2, the number of records that is used to give the order number count
Customermize cell A2 is “up and down expansion,” and left the parent grid of “B2”
the extended properties set
4.Get the number of records
Write the formula = A2 in cell A3 to get the number of records
Customermize cell A3 is “up and down expansion,” and left the parent grid of “A2”, as shown below
5.Set the report of condition properties
Right-click cell A3 and select “Condition properties”
When you add a “conditional property 1”, set the current record when A3 acquired value is a multiple of 6, then a “line after paging”, as shown
When you add a “conditional attribute 2”, set the current record when A3 acquired value is not a multiple of six, perform the third line “row height is 0”, that is the signature line that displays only the last page, as shown below
condition properties set
In this case, the final report template as shown below
report template
6.Report final results preview
1st page:
Report preview
2nd page:
Report preview
