How Dynamic Chart Works?
Made by FineReport
The above picture is a monitoring dashboard made by FineReport that contains dynamic charts. By clicking the corresponding position of the pie chart, you can display the data of the specific area, which is more interactive.
Let’s compare the data presented by Excel. Is it suddenly monotonous and cold? This is the most intuitive experience that dynamic charts can bring. Next, I will give you a clearer understanding of dynamic charts from the definition, advantages and production methods.
What is Dynamic Chart?
Don’t think that only if the chart can move, then it is a dynamic report, the accurate definition of the dynamic report refers to a report that does not have a fixed report template and needs to generate a template according to the actual business data. The core of the dynamic chart is that the data and chart types can be instantly displayed according to different conditions. In addition to showing the general static chart content, it must also have good interactivity.
In simple terms, the core of dynamic chart is that the report data can be called at any time. For example, if the boss wants to view the data of a certain month, he only needs to set a parameter filtering condition. When the boss selects the time and month in the control, the report will only display the data of which month. This is called a dynamic report.
The purpose of dynamic reports is to query and read data more conveniently and quickly. On this basis, dynamic reports need to contain a lot of logical functions, such as:
Parameter Filtering: Different conditions, the data you see is different, this is the basic function of dynamic reports.
Parameter Linkage: Link two or more components to achieve an automatic association between data. For example, click on the year sales, the order details of the year, the monthly return rate and the sales ranking will be linked.
Drill Down: The common functions of dynamic reports are mainly to achieve the expansion of infinite layer data and to expand the detailed data with higher dimensions. For example, the drill-down map.
Parameter Panel Dynamic Display: Due to some needs, in many cases, certain query conditions are required when certain conditions are met. For example, if you select a region, the subsequent parameter box will automatically display the city and consumers in the region.
Dynamic Query: If there are multiple tables in the database, how to improve query efficiency? At this point, you can set the dynamic data column, enter “jia” in the control, it will display the information with “jia” in all the tables:
How to Make a Cool Dynamic Chart?
Basic Chart Production Process
In FineReport, the chart’s workflow is similar to Excel, Data Preparation – Insert Chart – Select Chart Type – Select Category Axis, Series Name and Series Value – Set Chart Style.
How to set up?
 Different Charts
The table is mainly about the beauty of words, numbers, and grids, as well as the overall color harmony. These can be customized in FineReport.
You can even make a card column report, is it very special?
Data Visualization Widgets
In order to highly integrate the process of data analysis, better understand the business meaning behind the data. In addition to the type of forms, visual charts still have a dynamic display part, it is called dynamic visualization.
Dashboards
If you want the final product to achieve the satisfaction of your boss, keep in mind four points:
-Set the layout
-Match colors
-Decorate
-Dynamic effects
Then let us see the effect of a cool investment dashboard.
Made by FineReport
Tools to Make Dynamic Chart
Finally, for different roles in the company, they usually use different tools to create dynamic charts to visualize data according to their work needs. These three scenarios are the most common and wish can give you some reference.
Use Excel’s built-in charts to do some regular charts, from basic step graphs to pie charts. Advanced complex charts made by Excel such as dynamic charts, filtering display of charts can be achieved by writing VBA;
Using the coding language of R, Python, calling the chart function package, presenting the visual data, commonly used for data analysts;
Using open-source visual plugins such as Echarts, HighCharts, D3.js, embedding code, developing plug-in packages, often used by visual engineers, and front-end development.
Using business intelligence platforms such as Power BI, Tableau, or FineReport. The BI analytics is very powerful in customizing dashboards, creating beautiful data visualizations, building scorecards, and comparing them to key performance indicators (KPIs).
BI Tools | 8 min read
A stable business intelligence strategy is the foundation of the current use of business intelligence. Click to learn more about BI strategy.
07-26-2021
Data Visualization | 17 min read
Today, this article will review the top free and open source dashboard software specializing in project management, marketing, TV display, and so on.
11-05-2020
BI Tools | 11 min read
This post introduces the definition of business intelligence(BI) visualization and recommends 5 top bi visualization tools. Click to find out more.
06-17-2021
